F32/F99 Error on Kenmore Elite HE5t washing machine
This is for Kenmore Elite HE5t washing machine (11047788800)
The washer was giving SUD/F35 error. I replaced the Pressure Switch, and then the CCU. Now it gives F32 error at about 10 minutes of starting the wash. If I pull the plug and restart (so that the door will unlock), it gives F99, which goes away if I hit the power button, but F32 comes back in about 10 minutes of starting the wash.
The fill, spin, drain work just fine. I checked the pressure sensor tube at the top and it seems fine (although did not check the bottom, as it would require moving the machine). I cleaned the filter to the drain pump, and checked the pump for any debris.
Did I plug in the sockets incorrectly? What else could be the issue?
Ist dies eine gute Frage?
