Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1623 Fragen Alle anzeigen
Can't upgrade beyond El Capitan - screen unresponsive
I have an old MacBook Pro mid 2012 which had a broken screen. I sourced a replacement screen from a dead laptop and fitted it, but it has SUCH an odd issue.
I can install any version of OS X / MacOS from Mavericks to El Capitan and it works absolutely fine. All hardware tests OK both in the Apple Hardware Test and using Tech Tools Pro
If I upgrade or fresh install MacOS Sierra, High Sierra, Mojave or Catalina, the installer runs absolutely fine, until the final reboot when it runs the welcome routine. It gives the Apple logo, the progress bar goes until about 90%, and then it goes no further. The mouse pointer is visible and moves, and the voiceover starts with the ‘welcome to MacOS’ announcement, but the screen output will not progress beyond that.
I did try ensuring my user account had no password in El Capitan and upgrading to Catalina so I could log in without having to put a password in - there was a thread on the Apple forums about a similar issue which was bypassed by entering your password and pressing enter and the desktop appeared. No suck luck for me though…..
I’m a bit stuck on how to proceed. I don’t *think* it’s hardware related because everything works fine up to El Capitan.
Thanks in advance for any ideas.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Where did you source the display as you didn't get a compatible unit. The displays ID string is not correct for the system.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Here’s the correct part 13” MacBook Pro A1278 Display Assembly Apple P/N 661-6594
Update (10/06/2021)
@markjsy - Very odd!
Carefully disconnect the battery following the first steps to Step 4 MacBook Pro (13 Zoll, Mitte 2012, Unibody) Display Austausch then jump down to Step 14 and take a nice clear picture of both connectors visible like this image
So we can see whats messed up as thats the only other thing left.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
The replacement display comes from an identical MacBook Pro mid 2012, which didn't power on at all. With it being an identical laptop I presumed the display would be the same?
von
Antwort hinzufügen
markjsy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 31
