Zum Hauptinhalt wechseln
Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
58 Fragen Alle anzeigen
Plastic about to break again (second headset) around the ear cup joint
How do I prevent my current headset from breaking like the first one and how do I repair the first one?
This is the broken one
This one below is on the verge of breaking the exact same way. There is a crack in the housing coming from the location it attaches and I don’t expect it to last another month. SteelSeries will not fix it, will not sell me parts to fix it and would only sell me a new one. Warranty is not an option
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Ive bought this a year ago and I cant stress enough how carefully I handle headphones and how they were not say on or put on/removed carelessly, yet they broke in the exact same place... Sorry to say but for their price I find this flawed design unacceptable...
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
i had the same set. i love the sound quality but retuned mine due to how theyre designed. i found that if you remove them from their earcups that can put alot of extra stress on the joint there. instead try to grab the metal headband and take them off that way.
itll help remove the added stress to that joint if you grab the metal headband instead.
as for the the broken set… your best bet would be to try and disassemble them at that joint and use some epoxy to repair the damage joint ive had alot of luck with JB weld in the past but i’m sure there are other good options for plastic out there. be sure to thoroughly clean the area before using the epoxy
good luck!
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Exactly the same happened to me, really good headset apart from this joint. I won't buy another because you know its a matter of time till the joint breaks.
von
Ok so I bought a pair from a guy who had the cup break but nothing else was broken.
So what I did, took it apart and then messured the hole around the break, took a thin piece of plastic and shaped it so it fitted snug around the part that sticks into the broken cup. Now to the part that makes it unbreakable again. U will need any kind of plastic superglue (gorilla glue etc) and bakingpowder. So put glue and powder in a small container that u can throw away, now u need to be fast. Mix glue and powder and then put in the hole and glue the plate and headphoe pin into the cup again, the glue and powder will turn into a plastic cement. The only loss u wil have is the little wiggle u can do with the earcup left and right. But u saved your headset. The mixture is also repaintable with a common magic marker.
Bewertung 0
1 Kommentar:
Yeah it's a design flaw, great headset apart from this. I did NOT buy another as it will only be a matter of time (and not much time) before they all do this. I went for the razer blackshark v2 and for the price i prefer the razer over APs.
von
Arctis pro replacement link
Sells replacement parts
Bewertung 0
Replacement plastic piece link
Bewertung 0
I was able to find another replacement for the back side outside of the above link as I'm in the US. Found it on Aliexpress. Will report back after replacing it.
Original Replacement Headphone Outer Cups for SteelSeries Arctis Pro Wireless
Bewertung 0
1 Kommentar:
Did it go well?
von
Antwort hinzufügen
Yapsonark wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 24
Letzte 7 Tage: 128
Letzte 30 Tage: 553
Insgesamt: 15,660
