Zum Hauptinhalt wechseln
Das Google Pixel 2 ist Googles zweites Flagschiff -Smartphone, es erschien am 17. Oktober 2017. Das Smartphone ist mit einem 5" AMOLED Display ausgestattet und kann mit 64 oder 128 GB Speicher bestellt werden. Erhältlich ist es in drei Farben: Schwarz (Just Black), Weiß (Clearly White) und Blau (Kinda Blue).
70 Fragen Alle anzeigen
SIM tray broke in half, only half comes out. SIM and other half stuck
I've tried getting it with things like sewing needles but it seems if anything I've only further lodged it into place.
Photos:
https://imgur.com/a/bNEtEV8
I will take this thing apart if need be, however I'm not sure which, if any, of the ifixit Pixel 2 guides are what I'd need to be able to access it, or without taking way more apart than necessary.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @printedwaffles ,
I would use the Google Pixel 2 Hauptplatine austauschen guide to gain access to the SIM card reader where hopefully you may be able to gently push the broken tray and SIM card back out from the reader, without causing too much damage to the reader pins. Perhaps by using a Spudger you might be able to do this
Getting the reader’s metal case cover off may be difficult if you want to try and remove it to lift the broken pieces out.
If you decide to try this, don’t skip the part about disconnecting the battery from the board. You don’t have to remove the battery, just disconnect it. There is always power on the board even though the phone may be switched off and you don’t want to cause any more problems than what you already have. The power button is not a power isolating button.
Spudger Bild
Produkt
Spudger
$3.99
War diese Antwort hilfreich?
Bewertung 2
Or get some ifixit tweezers and carefully get the piece out
Tweezers Bild
Produkt
Bewertung 1
Antwort hinzufügen
Alberto Einsteino wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 1,066
