Zum Hauptinhalt wechseln
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
What is the middle battery connector for?
After Ipod touch battery replacement the battery has been getting stuck at 19% or less
then when it gets low enough the ipod shuts off,
and it take a while to get it to start up again with it plugged in,
Is it possible i got a defective battery?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
14 Kommentare
@beanman56 it's possible. where did you get it from?
von
I got my battery from ifixit,
so whats the middle connector for?
von
@beanman56 On the 6 gen I am pretty sure the centre pin is the battery data.
von
Is it needed?
Cus it was ripped off the board
von
@beanman56 Usually one or more pads come off when this happens. How’s you’re soldering skills?
von
9 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi
Hope you are well
I did not know really know how to explain this but I had a 6th gen that had the middle battery connection ripped off from previous repair and I noticed that mine would get stuck at 17% and when it would die it straight up wouldn’t charge again but there are test pads above the 3 battery pads and I found the one in the photo had a connection so I ran a jumper and it started working again so hopefully my complex explanation as helped
Anymore questions please ask
War diese Antwort hilfreich?
Bewertung 2
10 Kommentare:
Whats a jumper
von
@beanman56 A jumper is copper wire that you use when a trace or pad is broken between components. The average size wire is 0.01mm
von
@hellomacos - What size should said jumper be?
von
@beanman56 where you been Sir? Doing ok?
von
5 weitere Kommentare anzeigen
Antwort hinzufügen
Ben Capehart wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 805
