Zum Hauptinhalt wechseln
Das 3a gehört zur dritten Generation von Pixel Smartphones, ist eher preisgünstig und hat die gleiche Kamera wie Googles Flaggschiffe. Erhältlich in Schwarz (Just Black), Weiß (Clearly White) und Purpurartig (Purple-ish). Erschienen im Mai 2019.
70 Fragen Alle anzeigen
Black screen - Does't open after replacing with new battery
Followed scrupulously the ifixit guide to replace the battery in my google pixel 3a, everything went very well. After the replace, before gluing the screen, I charged the battery in order to check if the replacement works, to my surprise the charging percentage didn’t appear on the screen, even after an hour or so. Tried to put the phone ON, nothing. I disassembled the phone, checking for a loose connection, everything is fine … When the phone is plugged in the charger, it gets warm, but doesn’t open, screen dead … Anybody as an idea of what is wrong? Thanks!
Paul
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare:
This malfunction is common in some iPhone models, you must make a software for the mobile and it will return to work again But before that, make sure that you have installed the monitor cables correctly, taking into account the disconnection of the battery before installing the monitor.
von
Have the same issue, must've reseated everything over 12 times that I broke my proxy sensor cable eventually, the screen still won't power
von
Einen Kommentar hinzufügen
2 Antworten
You must first reinstall the screen and make sure that all its filters are connected with the installation care and you disconnect the battery. If the attempt did not succeed, make a software for the mobile, as this is a common malfunction for some iPhone models.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Hi Ahmed, thanks for your answer, but what do you mean by “make a software” ?
Thanks
Paul
von
And also, I can't disconnect the battery while the Screen is connected ...
von
Reprogramming the device by a specialist
von
I have the same issue now. Did you find a solution in the end? Would love to know
Bewertung 0
Antwort hinzufügen
Paul Abraham wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 434
