iPhone XR doesn't turn on
Hello, I have an iPhone XR which doesn’t turn on. It is not water damaged, and hasn’t been dropped. It shows no signs of life, and is not shorted. I tried hard resetting but nothing happened. When I plug it into the DC power supply and press the power button, it goes to 0.023 amps and doesn’t increase or decrease. Does anyone know what this issue may be? Thank you
Ist dies eine gute Frage?
2 Kommentare
Is any current draw occurring before you attempt to power? Do you have any other components connected when getting this reading? When you say it's not shorted, what specifically is not shorted?
I would suggest taking the board out, if you haven't yet to see if the issue is the same with no components connected. After that just look over the board as best you can, I don't remember how much of that board has shields over it, but even if it's the whole board, likely some just have stickers on them you can peel off. I know parts are REALLY tiny so it's hard to tell, but see if anything looks off: dull grey, singed, corroded, cracked, bent etc....
If you have a DC power supply, do you also have a multi meter? Do you have experience with micro soldering?
von Alisha C
Hello, there is no current draw occurring before I attempt to power the phone on. I tried powering it on with all components connected, then tried to power it on with all non-necessary components disconnected. Both tries failed. When I say it is not shorted, I mean when I turn the DC power supply on there is not an immediate large current.
I have taken the board out and have given it a thorough inspection under a microscope, and everything looked good. I am trying to not take any shields off unless strictly needed, so I'm not sure about the components under the shields.
I do have a DC power supply and a multi-meter, and a lot of experience with micro soldering. This phone has confused me though. Thank you for your comment!
von Colby Morris
