Zum Hauptinhalt wechseln
The HP Officejet Pro 6835 is an ink printer that has a built in scanner and copier. Pages can be printed directly via USB connection or over WiFi. The printer can be identified by its model number: J2D37A
How to clean print head To see if my machine will then work
My printer stopped printing and a message appeared the there is a printhead problem.
How can I clean the printhead to see if it will work before replacing it?
thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I’ve done it before on the HP 564 printers I’ve had (new, and ones I’ve literally pulled from the trash for a guide) and cleaning resolves it most of the time, but yes it’s not a 100% success repair.
The problem with yours is you’re stuck between a rock and a hard lack - not something easy to fix, a properly difficult one :(. Yours is the “permanent” type where it needs to come apart, so you lost your calibration for the head as it stands and it will probably demand “Setup” ink, and there’s a chance it wants the ones the printer shipped with. Unless you can get into the manufacturing menu (not easy - on the ones I had before I gave up on inkjet flat out you held the power button down but I forgot the other buttons you’re supposed to hold) and change the SETUP requirement to false, you’re dead in the water.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Catherine Busso wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 141
