Zum Hauptinhalt wechseln
Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
14 Fragen Alle anzeigen
Why can't I change the font size over 12
why can’t i change my font size pass 12
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
To enable changing the Font size selection to either 8, 10, 12, 16, 20, or 24, remove and re-insert the Batteries, which enables you change the variable Font settings. Use the Menu button to select one of 3 tape sizes: 1/4, 3/8, or 1/2 inch. The various Font sizes are dependent on the Tape sizes.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@jeanlouisk52448 @stevenburrows for the labelmanager 160 do a complete reset. That should restore your font options.
Turn the printer off
important - REMOVE THE TAPE from the printer
Now press and hold "Backspace" button the "9" and the "On/Off" button at the same time
You may need to try this a couple of times due to the awkwardness of pushing those buttons or try the ERASE option by
REMOVE THE TAPE from the printer. then press "9" and "Backspace" simultaneously, THEN the Power button.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
I did a complete reset including removing the tape. This time the tape options came up on the screen (they didn't on the first install). I chose 12mm and voila, I have the full set of font sizes. Thanks
von
@stevenburrows great. It seems like the reset needs more than one attempt due to its awkwardness :-)
von
Thank you for this explanation. I was losing my mind trying to figure out why I couldn't get a bigger font than 12. All fixed. :)
von
thank you, helpful though its awkward pressing those buttons that far from each other
von
Antwort hinzufügen
jean-louis kippelen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 28
Letzte 30 Tage: 116
Insgesamt: 1,240
