The problem you face is most of these ingredients don’t evaporate they just get into a gummy mess and will take a fair amount of time too dryout. Water would dilute them and with sufficient rinses you should be able to remove most of it. But you can’t use tap water! You need Pure H2O (distilled water) as anything else has salts and minerals in the water which will corrode things.
Then you need to dissemble your system so you can wash things as some parts just can’t get wet and to add to it as this is such a new system parts are as plentiful as a wooly mammoth tusk!
By chance do you have AppleCare+ if not, you might have a short window to sign up, with a contract Apple would fix your system for a smaller fee that a standard repair.
Otherwise I have no solution here. Liquid damaged systems are always iffy.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2 Kommentare
What is in E-Liquid? Besides the Nicotine & Glycol.
von Dan
@danj i copied this from google “ The e-cigarette liquid typically contains nicotine, propylene glycol, glycerin, flavorings, and other chemicals.”
von Abdullah AL-Raddadi
