Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
787 Fragen Alle anzeigen
MacBook Pro Keyboard Backlight Not working
So, I got this MacBook from a friend, as he didn’t have a use for it anymore, it was originally a 2010 model but it got a logic board replacement, idk if that affects it. there were some problems with the RAM at first but its fixed now.
Anyway, I often do use the MacBook in low light and I normally can see the keyboard. So I use the backlight but to my surprise the thing doesn't work! It shows up as working on the OS (10.12.6) but nothing happens, I have tried it on other os's to see if it was a os problem but no luck.
I have checked the board for water damage, none.
Checked the connector in the board and the actual cable, both fine.
there haven't been any other problems with the MacBook otherwise I am just asking if it is a problem with the logic board or if its the backlight itself
Hope to hear from someone who can help
cheers ;)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Have you made sure you check the proper cable?
Review this guide Step 14 MacBook Pro (13 Zoll, Mitte 2010, Unibody) Logic Board austauschen
Is the cable damaged? I’ve seen a few torn or the latch missing.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
No, its not damaged I've gone and done extensive analysis on the %#*@ thing but I haven't found anything clearly wrong with it.
von
@Aaron Official - Did you check to see if the connector has voltage? If it doesn't then that gets into the driver logic (could be a fuse as well)
von
Antwort hinzufügen
Aaron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 48
