Zum Hauptinhalt wechseln
15 inch "Desk Lamp" iMac G4 700MHz M6498 PowerMac 4,2
32 Fragen Alle anzeigen
Will an 800 mhz board fit in a 700 mhz model?
I am in need of a logic board replacement and I am wondering if an 800 mhz logic board will fit or be compatible with my (currently) 700 mhz imac g4 15”, or will i need to just get another 700 mhz board. also, if anyone can, is there a site that has these parts that is low enough in cost.
Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Yes, you can use the 800 MHz board in place of your 700 MHz.
Did you not try the source I pointed you to?
I’m sure you can also find the part searching Google by the part numbers.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Roman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 26
