Zum Hauptinhalt wechseln
Why is my tank empty in 3 minutes in mighty pro rug doctor X3/ pump di
Mine is the might pro x3 rug doctor and I can't find. But water goes fast has to refill every 3 to 5 minutes…and no button is stuck is it me…not letting off so or something? I can't find no pump diagrams ( JLT SOLENOID PUMP P4XXA P40202A
TYPE:
AC 120V 60Hz Internal Diode 50278 RUG DOCTOR L.P FENTON. MISSOURI SERIAL NO: 12H33) took apart to clean and blow clean hoses. From previous owners. Did at first, but didn't blow the hoses or trough the pump..finally did. Works greT just to much water
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If you pull out the clean water tank rectangular filter is the solution hose all the way to the bottom? Thats the intake hose and if the solution hose is midway up instead of in the bottom corner it will act like it's out of water, but you may still have a gallon in there.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Kenneth Kelly wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 381
