Zum Hauptinhalt wechseln
A2115 / 2020 / Prozessoren beginnend mit 3,1 GHz 6-Core i5, bis 3,8 GHz 8-Core i7. Markteintritt am 4. August 2020.
Power cuts out randomly, have to unplug from wall to reboot
So just the other day, my 2020 iMac screen went black, the power completely cut, and and no amount of holding the power button would get it to come back. I ended up having to unplug it from the wall, and then it would boot up again. This blackout happened a few more times that day, I tried shuffling around/removing RAM sticks and running the diagnostics, but nothing came back with issues or solved the problem. Eventually it stoped crashing, so I backed up some files and kept using it as normal.
Last night it started blacking out again, and now it can’t even get through the boot sequence, and safe boot makes no difference. This has now made me believe that it’s a hardware failure, and not a software issue. The closest thing I could determine is maybe a faulty PSU, but I really wanted to know if there were more rigorous tests I could do before ordering and installing a new one. Does anyone have any other ideas on what could be the problem, and how I could diagnose with more certainty?
Side note: I’m also remembering that I have had an occasional problem with this computer since I bought it (new) where the fans would suddenly spin up to maximum, sometimes even when it was sleeping, and none of the fan control applications I tried would ever actually register the RPMs. Sometimes they’d spin up for 20 seconds, and other times I had to shut down the computer and unplug it from the wall to make them stop. I don’t know enough about the hardware of this computer to make real educated guesses, but misbehaving fans and power management sound somewhat related to the SMC? Could the SMC itself be faulty?
Thanks,
Jak
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
SMC logic issues are rare, more often the sensor has detected a failure, and SMC goes into a latched state, so when you did disconnected the AC plug and held the power button you cleared the latch state and then the system works again until it hits the failure issue again.
If you are still able to get it to restart I would run the onboard diagnostics to see if an error code pops, if it does post it here so we can have a starting point.
If the system won’t start then you’ll need to carefully remove the display so you can check the diagnostic LED’s, review this for the details Diagnostic LEDs and Test Pads for iMac (Retina 5K, 27-inch, 2019) they are the same for the 2020 model as well.
I’ll warn you you need to use great care and use the proper tools and techniques as its very easy to damage the display! iMac Intel 27" Retina 5K Display 2020 Display tauschen
Here’s the needed tools:
Also you’ll want some painters tape to hold the display when needed.
Handy tool for opening devices, spreading thermal paste, and scraping. Same as Apple Tool Part# 922-7172 Bild
Produkt
Plastic Cards
$2.99
Cutting wheel for releasing the adhesive on some iMac models. Bild
Produkt
iMac Opening Wheel
$7.99
The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions. Bild
Produkt
Pro Tech Toolkit
$74.95
This custom fit wedge supports your iMac display during repairs. Bild
Produkt
iMac Intel 27" Cardboard Service Wedge
These replacement foam adhesive strips secure the display compatible with the A1419 model 2012, 2013, 2014, 2015, 2017, and 2019 27 inch iMac and the A1862 iMac Pro.  EMC 2546, 2639, 2806, 2834, 3070, 3194, 3144. Bild
Produkt
iMac Intel 27" (2012-2019) Adhesive Strips
$19.99
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
So, I’m extremely hesitant to post this because I feel like it will bring bad luck, but the iMac has been okay since your post. The only thing changed is that I followed your instructions to reset the SMC; other instructions I had seen said to just unplug from the wall, wait, and plug back in, but you mentioned I should have been holding the power button after it was unplugged. I’m not sure if that solved the problem, because I had this same issue a few days ago and then it cleared up for about two days before coming back. Hopefully it’s all sorted out now though, but I will report back if I run into more issues.
As an aside, the diagnostics (hold D while booting?) came back with no issues.
von
Antwort hinzufügen
jak33 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 458
