Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2011 / 2.5 & 2.7 GHz Core i5 oder 2.8 GHz Core i7 Prozessor
432 Fragen Alle anzeigen
Can I… Or should I Update?
I just got a mid 2011 iMac running OS X El Capitan. If I buy the upgrade kit would I be able to update my operating system?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
You should be able to upgrade it (to high Sierra) without the kit.
War diese Antwort hilfreich?
Bewertung 0
Here’s a link to the macOS files How to get old versions of macOS
I would recommend creating a bootable OS installer thumb drive and given the system you should stick with Sierra (HFS+ file system) or if you need something newer I would go upto Mojave (APFS file system) but that will require DosDude to run. High Sierra has issues!
Format the USB with a GUID partition map and a Journaled File System before setting it up following this guide How to create a bootable macOS Sierra installer drive
Bewertung 0
Antwort hinzufügen
Jeremy Crow wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 55
