Zum Hauptinhalt wechseln
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170 Fragen Alle anzeigen
Why is my monitor not working?
Hi I just have a quick question when I turn on my pc the monitor won’t turn on I check the hdmi of the monitor and tight it it’s still not working.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi,
More information is needed to help you.
Is the monitor powered on and does it have a message on the screen e.g. "no signal" or something similar?
Can you view the monitor's menu screens OK?
have you tried another monitor e.g. TV?
What is the make and model number of the PC motherboard?
Make and model of CPU?
Does the PC have a GPU card or are you using integrated video?
is the PC booting up OK?
What else have you checked?
von
Einen Kommentar hinzufügen
1 Antwort
if you have a gpu be sure you connected hdmi to the gpu if you don’t have connect the hdmi to the motherboard
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ryan Caron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 57
