Zum Hauptinhalt wechseln
Dispenser only works when left door is slightly open.
My dispenser only works when the left door is slightly open (1 inch ish). I’ve replace the magnetic switch sensors, and the one push sensor. Everything else appears to work properly. I have a Samsung RF28NHEDBSR/AA-00.
I’ve removed the top that contains the magnetic switches and put it back, but not clicked in on the left side, and it seems to be working.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hello, firstly hold the water button for 3 seconds to reset it. See if that works, if not check if you have warrenty with samsung! You can also trouble shoot testing these parts with a multi meter . Samsung Refrigerator Door Switch - DA34-00066C, DA97-13783A - Samsung Refrigerator Door Switch/Cover
Activates or deactivates the interior light when the refrigerator door is opened or closed. Bild
Produkt
$15.99
Refrigerator door switch/cover for detecting open or closed door status. Bild
Produkt
$38.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Randy Kirk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 264
