Zum Hauptinhalt wechseln
Reparaturanleitungen und Dokumentationen zum Google Pixel 5. Erscheinungsdatum 15. Oktober 2020. Modellnummer GD1YQ, GTT9Q
Earpiece Contact Pins Broken on PCB - No Sound For Phone Calls Only
Hello, I was replacing the battery in my Pixel 5 and one of the earpiece contact pins broke off and there is no sound on phone calls only but the other pin is still on there. Wondering if there is a way to repair the pin, or if there is some fix to where i make sound come out of the same way as music etc does, or if replacing the PCB is the only fix?
I have attached a photo of the pins from the repair guide and the one that got knocked out of place was the one on the left FWIW.
Thank You!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Same Problem here, even lost the pin, that came off. Realised there was a problem only after reattaching display. I would be ready to try soldering, but I'm not sure that it is even possible (at least for a beginnger like me) because connectors on PCP seem very small.
War diese Antwort hilfreich?
Bewertung 0
Managed to repair it with microsoldering but it wasn't easy. There's still a small dot of copper that you can solder to. You desolder the pad from the spring, solder it to the remaining microsopic dot of copper, glue it down with epoxy, solder the spring on top and it works.
Bewertung 0
Antwort hinzufügen
Google User wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 190
