Hi,
The wiring diagram in the tech sheet doesn’t give the pin numbers for the defrost timer but it appears that in cooling mode, the defrost timer gets it power through the defrost heater and the defrost thermostat (supplier example only to show location and possible cost).
See the Steps to enter electronic defrost control test mode (if applicable) (in the middle of the tech sheet) to check if the defrost thermostat opens and closes.
Here’s a video that may help with testing the defrost thermostat. If the defrost thermostat is faulty search for WPW10225581 to get results for suppliers that suit you.
Hopefully this is of some help.
@Ikaros Uranus
In defrost mode, is the heater actually getting warm?
Is the evaporator fan working in cooling mode?
In cooling mode check for voltage on timer terminal 2 (pink). If no good check on the defrost thermostat. If still no good check on the heater.
Here’s an image how I think that it works.
In cooling mode the red arrows show the path of the current to operate the timer. I think that the heater won’t get warm because there is not enough current for it but is enough for the timer.
When the timer operates after 8 hours to start the defrost, the heater is turned on because the timer contacts have operated bypassing the timer motor (green arrow through heater). However there is also still a voltage coming from the evap fan circuit (see green arrow through the evap fan which goes through the timer motor) which should keep the timer working but maybe not the evap fan.
After 21 minutes the timer contacts release and turn off the heater
(click on image to enlarge)
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
6 Kommentare
Can you post the wiring diagram?
von F Dryer
It's does not have one, tired of manually defrosting this fridge, just running continuously
von Ikaros Uranus
Virtually every refrigerator has a wiring diagram, either pasted to the back or folded several times and inserted into a crevice at the base behind an access cover for cleaning maintenance. I discovered wiring diagrams of my two year old fridge after removing the bottom grille to vacuum dust buildup on the condenser coils. The diagrams are folded into a small package and was inserted into a space. Some repair people need these diagrams or have to resort to online manufacturer's databases for technical info on repairs.
von F Dryer
Hi,
What is the model number of the refrigerator?
von jayeff
Whirlpool WRT111SFAW00
It working for 13 year age now, defrosting problem it have rite now, brand new timer and Heater
von Ikaros Uranus
1 weiteren Kommentar anzeigen
