Zum Hauptinhalt wechseln
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
My truck doesn't like hills?
My truck with 99k miles. Seems like it's slipping when going up hills. When it first started happening I would just hit the gas harder but one day I realized it was only doing it at 1200-1300 rpms when when I got the gas pedal about half an inch or more it would jump to 2k rpms. Yesterday it happened 2 times at 2200ish rpms. When going up a decent incline. I have no idea what it is or what I need to check. I'm not rich. So I need to be pointed in the right direction before checking everything. I'll only be able to check one thing a week because I just don't make much moneys. Thanks for your help if anyone can respond.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Is there any lights on the dashboard
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
First thing I'd ask you is it a standard manual shift or is it a automatic transmission? More than likely you have a automatic. I would suggest that you should check the transmission fluid. It sounds as if it's low of fluid and slipping. If you don't know how to check it I suggest you find some one very soon that does as this can cause much bigger, more expensive to repair problems.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Nicholas Phillips wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 107
