hello Johan,
You don't write anything about iPad's origin, about its last known moments. This is very important information that you need to take to take any action. My guess is that the tablet shut down one day and was under repair somewhere. I think he is just as raped as anyone else for now, with similar experiences. <br>
In a few cases, these were damaged pins in the charging port (in which case electronic confirmation is required). In others, in most cases, if someone opened the iPad, most likely, when trying to disconnect the battery, he broke the power contacts. If you are into microelectronics, you have to remove the board and check the connections. If you cannot solder and do not have the necessary technical background, find a good repair shop - really good one, you have to confirm its references - otherwise your tablet will never turn on again (due to lack of technical knowledge - most of them are still learning on YT).
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2 Kommentare
@refectio maybe know ?
von Johan M
Does it draw any current when you connect to the computer, but keep it on DC power? It won't boot without the battery connected, but it will at least prompt the unit to turn on in a way that's not related to the power button.
von Alisha C
