Zum Hauptinhalt wechseln
The CFS-204 is a 90's style analog AM/FM radio and cassette tape player. It can be powered by either six C-cell batteries or A/C power from a standard wall outlet.
Warning about opening plastic case
I have a similar Sony CFS-B11 with, I suspect, a broken belt in the tape player mechanism. The case carries dire warnings about electrocution upon opening the case. What do I need to do, beside unplugging the radio cassette corder from the electrical outlet, to open the case safely?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Thanks! So helpful!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @sandhillgirl,
You may get a tingle from some capacitors discharging if you accidentally touch some sections of the power board with your fingers but that's about all. To prevent this from happening, after you've disconnected the power from the player, turn it on for a few minutes, to discharge any remaining charge in the capacitors. It won't turn on of course, but they will still discharge in trying to turn it on with no power connected ;-)
Here's a link to the service manual that will help. Be patient as it takes a little while to find the file after you have passed the security check.
It shows how to disassemble the player and the belt can be seen on p.6 in the tape adjustment section.
The belt part number is Sony 3-362-989-01. Search online using the part number only to find suppliers that suit you best.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Lisa wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 48
Insgesamt: 536
