Zum Hauptinhalt wechseln
The a7R II (model no. ILCE‑7RM2) is Sony's 2015 revision to their full-frame, mirrorless, interchangeable-lens camera.
29 Fragen Alle anzeigen
Menu switching on its own uncontrollably
Hi, i owned a Sony A7ii for 3 years now, brought it 2nd hand. Had no issues in the past 2 or 3 years.
BUT as of today seems to have minor issues the past days but today it worsens the Menus are switching uncontrollably on its own and sometimes it goes back normal.
I tried to switch ON and OFF the camera or change the battery and remove the cage etc . seems to work for a bit in a few clicks but will begin to switch menus again....
Its very risky to use now...maybe it will delete all the files and photos.
Anyone here having the same ISSUES with their Sony A7ii camera or knows how to FIX this problem?? Would be much appreciated. Thank you in advance :)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi I've just encountered basically the same situation as you today. For me it started yesterday with scroll wheel not working properly.
I'm stuck with with 10s timer on auto now so unusable.
Just wondering if you found a fix for it?
Read somewhere that it might be the wheel, so may try and replace it myself
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
The Guy Next Door Productions wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 298
