Zum Hauptinhalt wechseln
Die Apple Watch Series 1 ist eine Überarbeitung der ursprünglichen Apple Watch, sie wurde am 7. September 2016 angekündigt. Die meisten Teile sind die gleichen wie bei der Series 2
123 Fragen Alle anzeigen
Green Snake, Red Snake, Won’t charge
My original Apple Watch s1 battery was expanding and pushed the screen off the body of the Watch. So I replaced it with a battery from ifixit. The watch now shows the red snake when not charging, and green snake while charging. No matter how long it charges.
If I let the watch off the charger for a week or 2, and then charge it, it’ll boot up and work normally for a day. Until it’s time to charge again. The battery continues to drop even while charging on the original apple charger, and then die, and go back to the snakes.
Any suggestions?
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
I have the same problem. After looking online at every video and picture of the battery installed I may have found the answer, but I would need confirmation… the negative and the positive are reversed on the battery ifixit sells as opposed to the OEM. I have purchased 2 now with the same set up. I have pictures but don’t know how to upload them.
von
Make sure there are no tears in your battery cable
I had this issue and that’s what’s caused it:-)
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sounds to be a faulty battery,
Contact ifixit for a replacement replacement battery
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Matt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 276
