Zum Hauptinhalt wechseln
This is a troubleshooting and installation guides device page for the Sony PS2 Slimline SCPH-7500x. The Sony PlayStation 2 Slimline computer system is small, slim and a network ready game console.
31 Fragen Alle anzeigen
Why did the PS2 Power Die?
Okay so today I bought a PS2 that was broken. The power button lit up, but wouldn’t start up. So I knew there was power going through, just not starting up.
Before I opened it I got curious about my power supply. The guy I bought it from gave me a supply that allowed me to adjust voltages, and the polarity. I got curious and decided to switch the polarity since I was generally curious about what would happen. The light no longer lit up on the console, and so I just assumed it meant the power was cut since it was going the opposite direction now. So I switch it back, but now the console power light won’t turn on at all. I have cleaned it at this point and I’m considering resoldering the solder points for the power port. But I want to know what happened when I flipped that switch.
A PS2 has a Polarity for - o +. I switched it to + o - for only a few seconds.
I’m fixing this and someone is interested in buying it from me in a month. I want to know if I can’t fix it anymore and should order a new one to work on, or if it’s not a big deal and I can fix it.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I'm no expert, but curiosity killed the cat. What I'm saying is, by flipping that polarity, no matter how short of a time for, you definitely fried a power management chip or some part on the voltage regulating circuit. They're designed to work in one way only, yeah they may have tolerances, but they're not much. Think of a zenner diode, they work great in one way, but reverse it, and it breaksdown and is no longer useable. Sadly bud, I think you killed.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
This answered my question. Man this sucks but at least now I know what not to do. Thank you so much!
I’m the bright side all the other parts are probably fine. So if I can find a replacement motherboard, or get my hands on another, I should be fine.
von
Antwort hinzufügen
Jake Allen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 221
