Zum Hauptinhalt wechseln
JBL Flip 4 tragbarer Lautsprecher. IPX7-wasserdichter Bluetooth-Lautsprecher, der mit dem CES Innovation Award 2017 ausgezeichnet wurde.
83 Fragen Alle anzeigen
Why do the power and sync lights dim when the bass hits?
Used it on my ATV numerous times it worked fine til awhile ago I started hearing crackles each bass thump when I pulled over to check it out (while still playing) I noticed the battery low and for some reason it seemed to drain energy from the LED lights? (Blue power light started to dim each time the bass was hitting same goes for when I turned on the sync light to check if it was just a bad LED bulb) what could be causing this (note the speaker wasn’t mine originally a friend gave it to me and it has been working fantastically til just today)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Whenever bass hits it consumes more current and uses ampere and voltages. If you have heavy speakers compared to the handler it normally happens. You need to use a high capacity transformer. Copper transformers are best for amplification.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
It’s the portable Bluetooth speaker not their home speakers
von
Antwort hinzufügen
Marcos Flores wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 34
