Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für das iPhone SE der 2. Generation, im April 2020 angekündigt und veröffentlicht.
iPhone SE 2020 battery replacement “non-genuine ” message
Hi, I want to change an original iPhone SE 2020 battery with an iFixit one. I’m wondering if I’d get a “non-genuine battery” message like the iPhone 11. Someone knows if I’ll get this message after a battery replacement? Thanks in advance!
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
7 Antworten
Hilfreichste Antwort
Yes you will get this warning on the SE 2020 model.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
is it a popup like "Touch ID is unavailable" or is it a persistent message that makes using the phone difficult?
is there a fix for this?
von
yes i also get this message
von
Yes, I get this message.
Bewertung 0
Hi There, you will not receive and error message normally only happens on XS and upwards.
Bewertung 0
1 Kommentar:
this comment doesn’t solve the problem!
von
100% correct i tried it and works
Bewertung 0
1 Kommentar:
i can’t change my phone to solve the problem! I bought the correct battery from ifixit … and have a permanent error message.
von
is the message permanent and a hard reset changed nothing? (that’s my experience)
Bewertung 0
The message is not permanent, its very obvious the first two weeks, then it gets tucked away into SETTINGS/GENERAL/ABOUT after that. if you replace the battery with a genuine apple battery, you can run the included 'repair' in iOS 18 and it will remove the message. if your good with tools, and you changed the battery on your own, you can find snap on tech that can make the battery seem genuine. some of these snap on flex things will require you to remove the connector from the original battery and put that on the new one. youll find videos online about it
Bewertung 0
To stop the genuine message, either update to latest software AND use an apple original battery (pricey), or get a battery with extended tabs and spot weld it to original battery's bms (risky)
Bewertung 0
Antwort hinzufügen
Sergio Catania wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 33
Insgesamt: 2,871
