Zum Hauptinhalt wechseln
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
Lost keys replaced ignition cylinder with used one from another
Replaced ignition cylinder with used one from another 05 escape how do I program key
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hello. Unfortunately, there is not a proper DIY method as this is a security issue related to the vehicles control modules. If you are having trouble with the transponder key itself, this will require a compatible scan tool to initiate the programing sequence for the vehicle at which time the technician can wipe the memory of the previous keys to prevent future theft. This may be achieved at your local dealership or a local mechanic and or locksmith may have the necessary scan tool to program the key.
I am assuming you may be interested to program the remote keyless entry fob as well. If so, please find the following link. (871) 2005 Ford Escape: Programming remote keyless entry remotes - YouTube
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Tim Grim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 115
