Zum Hauptinhalt wechseln
Die Logitech 502 Lightspeed ist eine kabellose Gamingmaus, sie hat praktisch die gleichen Daten wie die kabelgebundene G502 Hero.
4 Fragen Alle anzeigen
Frage geschlossen
Wobly left mouse button, need ideas or advice
I replaced switches on the mouse after they start double clicking/not holding. Then I was disassembling mouse, the front of two screws which holds left button broke, it's bottom half stuck inside and a hat fall off. Now only one screw holding button down, and it's causes the mouse button to be out of place, slightly higher then it supposed to. I tried to put a little glue, to hold it in right position, and it worked for a couple of days, but after a several gaming sessions, a glue fall off. Also tried to extract bottom half of screw, but I think I only ruined the socket. I need any advice, how to hold button on proper distance and I'm out of ideas.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Albert Veresk post some pictures with your QUESTION of what you got going on there. That way we can see what you see Bilder zu einer vorhandenen Frage hinzufügen
von
Einen Kommentar hinzufügen
1 Antwort
Try contacting Logitech, they can probably help you
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 277
