Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s Plus gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
1041 Fragen Alle anzeigen
I have been dealing with my phone overheating
I have just took my phone apart and turned it on and felt where the one spot of incredible heating is taking place, It's in the mess of display cables. I was curious about what this means for replacement parts, What part should I replace? My display, battery, Cables?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
When the iPhone 6s or 6s plus starts overheating and the heat is coming from the top of the board it usually means the Wi-Fi chip is has a short inside it. The Wi-Fi might still work for now but it will not be long before the phone will be inoperative due to overheating. The Wi-Fi chip is located on the underside of the board under the display connectors.
I would suggest an upgrade as the repair would be more expensive than the phone is worth as replacing the chip is not straight forward and you also need to unbind the Mac Address from the NAND for the new chip to work.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
%#*@, the whole reason I was looking for a repair was because I ain't got any money. Well thank you !
von
Antwort hinzufügen
Lfjnjd0liffhahf wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 53
