Zum Hauptinhalt wechseln
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
No hot water in boiler, keeps flashing F5?
My furriol boiler keeps flashing F5, and am only getting hot water for a couple of seconds at a time, will i need to get a new boiler, or can this be fixed?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Have you switched boiler off and re-pressurised the system?
von
Yes turned it off and turn it back on left it for a period of time
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Lindsey, not sure what boiler you have, the only info I got is for a Ferroli boiler. Again, there are numerous of those. If you can a model number would be helpful. On the Ferroli Optimax the F5 error code is:
Fan problem
• Tachometer signal
interrupted, fan connection
• Fan damaged, debris in fan
Possible Solution
• Check the wiring and fan
• Check the fan, clean debris
Hope this helps you to get started. Good Luck.
War diese Antwort hilfreich?
Bewertung 4
6 Kommentare:
F5 fault What a nightmare! I removed the fan and checked the fan using a plugged twin cable attached to the live and neutral point of connection on the fan itself. After discovering it was seized I had to buy another, that was the easy part!!!
Installation was a success but the fan still wouldn’t work it seems to be a PCB problem.
My advice to homeowners and engineers You spot a ferroli run away!
von
Ive worked on ferrolli for 15 years.
Over the past 10 years I can diagnose faults on most ferrolli boilers over the phone
von
I’ve worked in ferrolli boilers for 10 years., In the uk ive found that some models have the Same faults.
von
I also have the issue of the fan not working, but in my case, the fan is ok, has continuity and resistance of 47.6 ohms.
The issue is, the fan isn’t getting power from the PCB so is the PCB at fault or something else? Can anyone help?
von
Could anyone please advise me on F5 fault code on ferroli boiler
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Lindsey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 18
Letzte 30 Tage: 51
Insgesamt: 32,773
