Phone keeps restarting after battery & lightning assembly replacement
Device: iPhone SE 2020 126 GB, iOS 15.4.1 (I think)
Issue: Phone turns black and restarts every few minutes after replacing battery and lightning port assembly.
Back story and tried solutions:
My headphones kept losing connection when plugged into the lightning port (especially when the phone was in my pocket and I made certain movements like walking up stairs or cycling) and after replacing headphones twice and cleaning out the lightning port thoroughly I decided to replace the lightning port assembly, and while at it I also decided to replace the battery. I used the guides here on ifixit.
The replacements seemed to work fine and the phone and all its functions worked without a problem. The only issue (which renders the phone unusable) is that the screen turns black and the phone restarts after using it for a few minutes. This happens both when connected and not connected to power and seems to happen no matter what I do with the phone. Airplane mode or removing SIM-card tray does not resolve the issue. However, the phone does not seem to keep restarting if it is locked and not being used.
I suspected a bad battery and switched back to the old apple battery. Same issue, phone works perfectly but keeps restarting.
I DFU-reset the phone in case it was a software issue but the issue prevails.
There are two known hardware issues that occurred during my replacements:
- I lost one of the tiny 1,3 mm phillips screws to the upper bracket covering the upper front panel connector, but the bracket keeps snug with the remaining screws and I doubt this would affect anything.
- While replacing the battery for the second time I got impatient and was too rough and probably damaged the wireless charging coil beneath the battery, but this occurred after the issue started.
Is there any other solutions I could try? Any specific hardware that I could trouble shoot? When replacing the lightning port assembly almost all components were removed so could be anything, but I feel like I managed to put everything back together where it should. The thing that was really tricky was to get the little coax connector of the antenna convertor cable to fit on the new lightning port assembly, but it seemed to fit just fine and wifi and 4G still works perfectly.
I don't think any repair shops will take my phone, much less any apple-certified technicians and can't get any money for it so at this point my only solution is to toss it and get a new phone... A pity since it is still quite new and worked perfectly apart from the headphones issue. :(
Ist dies eine gute Frage?
