should I clean my fans manually or replace them?
my fans are dusty and i am wondering if i should clean them myself or just replace them entirely?
Ist dies eine gute Frage?
Cleaning is quite easy! Get a small soft pain brush and a can of can'ed air so you can blow out the dust & debris.
I would follow these two guides as its better if you remove them:
Carefully scrub the blades as well as the heatsink fin areas. I blow the air outward across the fins and a few short blasts on the fans. You don't want to spin them up, I often carefully wedge a toothpick to hold the blades from moving. Don't for get the give the logic board a quick wipe as well with the brush and then blow off what you've loosened up.
Anleitung
Schwierigkeitsgrad:
Mittel
45 minutes
Anleitung
Schwierigkeitsgrad:
Mittel
20 minutes - 1 hour
War diese Antwort hilfreich?
Thanks for the help
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 88
