Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
130 Fragen Alle anzeigen
How to remove the Keyboard/Touchpad connector board
I need to replace the topcase came with keyboard only, does someone know if it is easy and possible to remove the Daughterboard from the old case
Update (06/01/2022)
i am talking about this board
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
I am talking about the little board underneath keyboard as listed here https://www.aliexpress.com/item/10050019...
von
Ah! You picked the wrong system! You are looking for the newer M series which is different! I've altered the model identifier so its set for the late 2020 not the early 2020.
von
Thanks, sorry for my negligence
von
Einen Kommentar hinzufügen
1 Antwort
Can you explain a bit better, the top case keyboard doesn't have a daughter board as you can see here
Are you thinking of the trackpad?
Update (06/01/2022)
@Sami Rahman - Thats the back of the trackpad
Here's the guide to replace the trackpad MacBook Air 13" Anfang 2020 Trackpad tauschen and if yours needs replacement here's the needed part MacBook Air 13" (A2179, Early 2020) Trackpad
Be careful here! the Early 2020 (Intel) is different from the M based Late 2020 model
Update (06/01/2022)
The M series daughter board is glued to the uppercase using double sided tape which is quite tight. Using some Ethanol alcohol dripping a little around the boards edge should help is loosing it. You don't want to pry the board up with too much force as that will damage it. You appear to have found the board so it maybe easier to replace it.
MacBook Air 13" (A2179, Early 2020) Trackpad Bild
Produkt
$109.99
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
I have finally done it during replacement of one liquid damaged top case. Beware of very strong black adhesive underneath and be extra careful while prying it to not bend it rendering it useless
von
Is there any tutorial about how to remove the keyboard connection board?
von
@eygjpefiy4yex2q - Its just glued down, but quite well! Using a solvent to help loosen the grip is all you need and patience lifting slowly.
von
Antwort hinzufügen
Sami Rahman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 28
Insgesamt: 202
