Do I need to change wifi antenna assembly?
I replaced the battery and while opening up the screen, I tore off the wifi antennas from its assembly. However, the wifi still works after putting it back together.
The one thing I am confused about is, on this model, the antenna do not connect to anything on the motherboard, or am I mistaken?
There is a little metal piece on the bottom of the assembly (3rd pic) which connects to the motherboard but that piece does not attach to the antenna whatsoever.
I have attached some photos of what the antennas and the assembly look like in my case.
Thank You in Advance!
Ist dies eine gute Frage?
I came to your same questions as I cannot find any contact surface for the supposed antennas. Anyway my antennas are a little damaged as the ones in the pictures of the guide as it's impossible to save them from scratching in the opening procedure.
Could you even find a replacement for this metal parts ?
von Patrick De Angelis
You can purchase just the antenna for a cheaper fix or the compete item. both are available on AliExpress. watch out on certain auction sites đ as damaged ones are being sold there, showing the foil parts missing! you may need to transfer the microphone in most cases. Available at a higher cost on Amazon, but quicker delivery. Make sure you order exactly the right one.
von Helping Hand
