Zum Hauptinhalt wechseln
Stift für das iPad Pro (3. Generation) mit Gestensteuerung und magnetischer Befestigung und Aufladung. Herausgekommen im November 2018. Modell A2051.
18 Fragen Alle anzeigen
How can I remove the tip that’s snapped off on the inside?
I dropped my Apple Pencil a few days ago and the tip snapped off. I ordered some new tips and I tried to screw one in with no luck. I looked it up and a piece of the broken tip might still be inside the Pencil. How can I get this out?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hi
First of all I must say I am sorry to here of this unfortunate event but not to worry as we can fix this!
There is the bottom part of this Tip still inside
Here how to get it out!
My advise would be to get a sewing needle and start scraping away a little of the plastic (on the bit stuck inside)to create a little slope in the bit that’s stuck inside just until you can turn it out
Hopefully this helps but if it doesn’t comment on my answer and il help you get back on with drawing with your Apple Pencil!
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
@oldturkey03
Thanks for letting me know
I had no idea!
Thanks again:-)
von
Il give it my best shot!
von
Hey I got mine out by using the broken tip. I slid it over the metallic transducer, till it meshed with the broken bit, then unscrewed it (anti-clockwise looking at the pointy end) with some light pressure. Your mileage may vary depending on the shape of the break though. Good luck everyone!
von
I didn’t know this was a thing till it happened to me! So I took a pin and made a small hole in the stuck hub of the tip till the pin was and then started rotating the stuck part counter-clockwise till it came up. The gave the pen a shake and it popped out. Thank you for the solution!
Bewertung 0
Omg this is what has happened to me and why I’m here. I’m so glad I’m not the only one this has happened to. I’m giving this advice a try now. I hope it works.
Bewertung 0
Antwort hinzufügen
Anja wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 27
Letzte 30 Tage: 121
Insgesamt: 5,976
