Printer will no longer fax
My printer will no longer fax or answer. Line to printer tests good. Everything else works perfectly with the printer. When is goes to fax I get a notice that "unable to send or receive faxes".
Ist dies eine gute Frage?
Hi @jimwsr ,
Try running the test fax setup from the printer control panel and check what it shows. See p.220 in the manual
War diese Antwort hilfreich?
define "LINE IS GOOD" and how you know?
Is the scan and fax method is ON?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 117
2 Kommentare
I plugged the cord from the wall into an old fashioned phone.
What do you mean,"is the scan and fax method on"/
von James Wildgust, Sr.
@jimwsr I read that in a google search about your problem. I have no idea what that is, and if you don't maybe that is your problem.
von bill
