Zum Hauptinhalt wechseln
I need to replace the HHD with a SSD on a Lenovo IdeaPad 330-15IKB
I have a 4 year old Ideapad 330-15IKB.
Is it worth replacing the Hard Disk drive with a SSD?
If so, what SSD is compatible and is there a guide for installing it?
Is the installation similar to this guide for the IdeaPad 330-15AST:
Lenovo IdeaPad 330-15AST Hard Drive Replacement
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @dan8976
Here's the hardware maintenance manual for your laptop.
Go to p.46 to view the necessary pre-requisite steps and then the procedure to remove the HDD.
Installing an SSD is just reversing the procedure used for removing the HDD. The only difference is that most SSDs are only 7mm in depth and HDDs are much thicker so a spacer will have to be inserted under the SSD in the drive bay to ensure that the SSD is at the correct height for the connector.
Here's a link to just one supplier that may help. It shows the type of SSD i.e. sata, the maximum capacity and also that it comes with a spacer. Knowing this will allow you to find other suppliers that may suit you better.
Also most reputable suppliers provide a link to download cloning software along with the SSD so that you can clone the HDD to the SSD and have a seamless transition to the new drive.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks. Very much appreciated.
What brands of SSD do you recommend?
von
@dan8976
Recommendations are very subjective so I suggest that you check online as there is lots of information as to what to buy.
Here's just one link.
Don't forget that you need a sata SSD. ;-)
von
Antwort hinzufügen
Daniel Green wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 45
Insgesamt: 1,581
