Zum Hauptinhalt wechseln
Reparaturanleitungen zu haushaltsüblichen Ventilatoren, inklusive Stand- und Deckenventilatoren.
20 Fragen Alle anzeigen
My motor won't work
How can I tell if my motor is burned out
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Motor for what? Need more info such as what the motor is powering and such?
von
Einen Kommentar hinzufügen
1 Antwort
I'm guessing you're asking about a ceiling fan. Could be wrong. But to check it you need a multimeter. Do a continuity check from N to ground, and from each winding. Then to a continuity check across each speed to N. If I remember correctly the slower the speed, the higher the resistance. If it shows continuity to ground then it's toast. If it show OL from any speed to N, then it's toast. If each speed reads the same amount of resistance, then the windings have shorted together. Also check the capacitor. Now, in the event you aren't talking about a ceiling fan... this should still work. Unless we are talking about ECM motors. Those are more complicated but much less common.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Joseph Sanchez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 62
