Zum Hauptinhalt wechseln
Reparatur- und Demontageanleitungen für Samsungs Flaggschiff-Android-Smartphone S21 Ultra, das im Januar 2021 veröffentlicht wurde.
57 Fragen Alle anzeigen
Rear back camera lens/glass cracked, any issues using 3rd party lenses
I'd like to avoid taking the entire back panel off and it seems the old camera glass can be pryed off and the new one installed. Wondering if anyone has done this/ how the 3rd party glass compares to Samsung OEM back camera lens glass?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi Fed,
Personally, I've replaced lenses on my Pixel 2 and a couple of iPhones and never had a problem with aftermarket glass.
There is something to be said for removing the back cover to do the replacement. For me, the main advantage is that you can do a better job of cleaning out any broken glass particles from the camera lens(es) with the cover off, plus you can push the old lens out from the inside and avoid scratching your housing while prying out the broken glass.
There's a decent video demonstrating the whole process over at iphonewired.com: Samsung Galaxy S21 Ultra Camera Glass Restoration - iPhone Wired, but all in all it's a fairly easy process whether you decide to remove the back or not. If the glass just has like a single crack I'd go for not removing the back, but if it's shattered with glass shards you might want to consider taking it off.
Best of luck!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Fed wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 182
