Zum Hauptinhalt wechseln
Released in Sept, 2018 by OPPO
My phone is not turning on
Before 1 month ago my realme c1 phone was suddenly turned off then I go to for repair they changed the folder and it was working after 15 days it happened again and my phone has been turned off while charging time.
Since then my phone is still not on.
Can you help me।
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Try to press and hold the power button for few minutes and repeat this process and check if its works.
War diese Antwort hilfreich?
Bewertung 1
If there is lint in the charge port, the cable can't seat properly and this can prevent it from charging at all. VERY CAREFULLY use a pin or needle to check that the phone's charge port is clean.
Bewertung 0
Antwort hinzufügen
THIS IS PAVAN KASHYAP wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 26
Insgesamt: 1,147
