Zum Hauptinhalt wechseln
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
156 Fragen Alle anzeigen
System powers on when power cable is connected. It can't be shut off.
The system will power on and not shut off. I swapped power supplies, and power button. Nether worked. I disconnected the power button and plugged in the console. It powered on. What can I do to fix this?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Have you tried a hard reset? Press and hold the power button for around 10 seconds and see if it helps.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
No this didn't work
von
Short of replacing internal parts you can always unplug it or connect it to a switched power strip.
Bewertung 1
1 Kommentar:
Ya. Well I'd be fine with replacing internals if it didn't seem to be a motherboard problem. But if the power button is held then the ejection button is pressed it shuts off normally
But it has to be timed to let your fingers go right away or it will power back on and eject the tray
von
Antwort hinzufügen
David Staffen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 45
