Zum Hauptinhalt wechseln
Das ist die LTE-Variante der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7 Zoll Retina Display und einem 64 Bit A9 Prozessor.
Panic (cpu 0 calller) after battery repair
Did a battery repair on iPad 5 Cellular. After customer left with ipad it began to boot loop every 3 minutes. Shows PANIC (CPU 0 CALLER). I have already replaced the charging port but still the same issue.
Any ideas?
Thanks
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
This is likely some issue with a sensor checking in. This is almost always the case after a battery repair. It’s possible the new battery is defective. Or the battery connector on the board sustained some damage during the repair. The data pins in particular are prone to bend.
Can you post a copy of the full panic report? Or at least screenshots of the first page or so?
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I have a picture of the panic log below
von
@store0667 The panic you posted indicates pretty much what I expected. There is a battery sensor (TG0B) which the iPad is not getting communication from. The issue is going to most likely be the new battery, or damage to one of the pins on the battery connector. I would recommend taking the board out to inspect the underside of the battery connector.
von
Here is some of the Panic log.
Thanks
Bewertung 0
1 Kommentar:
How did you disconnect the battery before disconnecting the screens? Or what did you use? Does as mentioned before sound like damaged pins on the board. A pain but remove the board completely and take a look for damage.
von
Antwort hinzufügen
BP 667 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 8
Letzte 30 Tage: 61
Insgesamt: 1,248
