Zum Hauptinhalt wechseln
Die Xbox One S ist eine Entwicklung von Microsoft. Sie erschien im August 2016 als Neuauflage der Xbox One.
426 Fragen Alle anzeigen
Boots into error menu and offline update fails
I got this xbox one s from my friend in this state. It powers on into the startup error menu with E203 . I then proceed to offline update it and it gives me E101 immediately after starting. I haven't seen any solutions to this anywhere else so I thought I should ask it here.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Good afternoon from Australia,
Have you tried googling this? If not then maybe try looking at other places.
Based on what I have seen, replacing the hard drive might be a good idea as it could be a faulty hard drive (You never know)
von
Thanks I'll try it
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It turns out the hard drive was bad. I replaced it, performed the usb update, and it worked. Thanks for the help!
War diese Antwort hilfreich?
Bewertung 0
Hi,
There are a few things you could try
  1. resetting the Xbox to factory defaults
  2. downloading the update on a USB and installing offline https://support.xbox.com/en-GB/help/hard...
  3. Replace the hard drive
If I were you, I would try in that order and hopefully 1 should get you to the bottom of it
Bewertung 0
Antwort hinzufügen
Wyatt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 410
