Zum Hauptinhalt wechseln
Reparaturanleitungen für die 3. Generation des 11" iPad Pro (Modellnummern A2377, A2459, A2301 und A2460).
top volume button isn't working
the top volume button is stuck. is there any way to fix that?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
You'd have to remove the screen and maybe, depending on location remove the motherboard too. Then remove the plate behind the buttons to remove and clean them and the opening for the buttons. Unless the area around the buttons has been damaged. If you haven't removed a ipad screen before go real easy as there's a risk you'll break it.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you. Definitely helpful but I’m not that tech savvy. Have a great day!
von
Check your iPhone's volume settings (sound settings) to make sure that volume buttons aren't disabled. To do this: Open the Settings app. Tap Sounds & Haptics
Regards,
Will
Bewertung 0
1 Kommentar:
Thank you - will try that.
von
my power button is not working well, it is mostly stuck. Can this be fixed?
Bewertung 0
Antwort hinzufügen
Pam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 50
Insgesamt: 499
