Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
132 Fragen Alle anzeigen
Fix M1 Air: working after water damage EXCEPT Keyboard and Trackpad?
***Water spilled all over my M1 Air a few days because of an upstairs plumbing issue. It still works perfectly EXCEPT the Keyboard and Trackpad are non-responsive. Power button, fingerprint sensor, speakers, ports, display and backlights work. For repair, anyone experienced this? I'd like to fix it and am tech savvy.
Apple Diagnostics showed no problems. Deductible is higher than the cost of the device. I can't have it in a shop for multiple days. Either I fix it or it's getting replaced
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Have you opened the device up yet? That would be step one. Although liquid damage can be instantaneous, depending on where water went there may still be liquid somewhere on the internals. or minor corrosion that should be cleaned up. and you'll want to know where water went.
My thoughts are that this is probably related to either the trackpad, the keyboard, or both. Water gets into the trackpad area fairly easily since there's not a whole lot keeping it out.
There is also small board mounted to the top case, under the trackpad, which the keyboard connects into that could have seen some liquid. That board connects to the trackpad and handles some trackpad function and the majority of keyboard function. So I'm expecting your issue is going to be in that area. If you're lucky, the trackpad will be the only issue. If you're not as lucky, the little board on the top case might also have some water. Both parts are replaceable, but the little trackpad board can be difficult to source independent of the top case (which you may need to replace anyway if the keyboard itself is damaged)
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
It was sort of a perfect storm where the lid was open, directly under a toilet pipe and I wasn't there so it just sat wet for 30+ minutes. So essentially it soaked right into the keyboard with a decent amount of water coming in through the keyboard. I'm actually kind of surprised that it works at all honestly! I'm going to try and clean the connectors with alcohol, but without somehow finding parts to test it with do you know if there's a way to diagnose it independently?
von
@dorrough Yikes. Sounds like a nightmare. I’m surprised too. The keyboard itself might be toast in that case., but I will hope not. There’s definitely ways of testing things without known good parts, it just makes it a lot easier if you have them. I would start by just getting a look at everything and see what the damage is. If you have access to an external keyboard and mouse, back up your data if you are concerned about losing anything, just in case.
Edit some pictures into your original post once you peek inside, and I’ll be happy to have a look what you’re dealing with .
von
Antwort hinzufügen
D Dawg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 84
Insgesamt: 1,258
