Zum Hauptinhalt wechseln
The Huawei P20 Lite is a budget, yet powerful, smartphone from tech giant Huawei. It features dual rear-facing cameras and an amazing display.
45 Fragen Alle anzeigen
AP_S_ABNORMAL 64 Error - Unlock Smartphone in Fastboot&Rescue Mode?
Hello all,
My Smartphone (Huawei P20 lite) updatet over night and got stuck in a bootloop. The only Menu i can enter is the Fastboot&Rescue Mode. In Fastboot&Rescue Mode The Android reboot reason: AP_S_ABNORMAL 64 is shown. Phone Locked, FRP Lock.
Does Anyone know a way to save data like pictures from this phone in this state?
My cat died last month and i would loose all my pictures with her. I would really appreciate every help to save those pictures.
Thanks for Help
Kaitokiddo
Update (29.09.2022)
My Smartphone (Huawei P20 lite) updated over night and got stuck in a bootloop. The ONLY Menu i can enter is the Fastboot&Rescue Mode. In Fastboot&Rescue Mode The Android reboot reason: AP_S_ABNORMAL 64 is shown. Phone Locked, FRP Lock.
Thanks for Help
Kaitokiddo
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
There is a problem with the latest HUAWEI update bricking phones with no way of getting out of it I’m afraid. Hopefully you are not one of the unlucky ones. Try connecting your phone to a pc and use Hi-Suite to try and repair the firmware. Don’t do a restore or anything like that or you’ll lose your data.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I would do the following: first try to force stop the phone by pressing and holding the Power button for more than 15 seconds
If this doesn't work you can try 'wipe cache' and 'safe mode' methods (see here)
Finally, to make the phone work again you still have erecovery(check answer to post #3 in Huawei Community thread)/ReiBoot option but supposedly this will destroy your data, as it will doing a factory reset
Good luck, let us know if you were able to fix this
Update (10.10.22)
Idk if you already tried this or if it's possible at all in the current state ur phone is in, however you could boot into a custom recovery like TWRP (won't overwrite/install anything on the device, sort of like a live distro) after patching it to include /data/media (the internal storage accessible from your phone, including DCIM folder) in the backup (or use this method) and simply make a NANDroid bkp by following this guide until the "fastboot boot twrp.img" command. The recovery file specific for your device is downloadable at this link (Huawei P20 Lite codename "anne").
I don't think you'll need an unlocked bootloader for this, as you're not flashing the image but just booting it for recovery. Of course if the device is out of space you will have to plug an OTG cable+flash drive or insert a micro-SD card with enough free space to save your data (should also be possible to save it directly on your PC, video is in French).
Being able to boot TWRP successfully, after backing up you could:
  • load the image on MultiRom (can restore nandroid backup as secondary ROM or boot from USB drive connected via OTG cable) on another Android device
  • virtualize the image on a PC as showed here, recover your data and hopefully restore it if you manage to unbrick the phone
Just speculating, you probably thought about this too, still I really hope it's feasible and you manage to access your data again
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Wipe Cache and safe mode is not a Fastboot and Rescue mode option ... but the only menu i can open is Fastboot& Rescue mode. Erecovery mode is not possible. When i tried it, it simply was a black screen for a bit longer like he would try to go into the eRecovery mode but he couldnt so the logo went up again -> normal boot process.
And i don't want to wipe cache i guess because i want to safe the pictures of my cat.
But nice try. Thank you.
von
IMO we gotta find a way get to erecovery, as on EMUI 9+ it should have a SAFE MODE entry; btw v9.1 seems to have a precious 'Emergency Backup' feature, see post #7 on this thread(https://forum.xda-developers.com/t/p20-l...). On older versions, the procedure to get to recovery screen could be slightly different (see post #2 on the same page).
By all means, as @strongbow suggested if your phone is supported also give HiSuite a try.
Last resort, disconnecting and reconnecting the battery ribbon cable has been reported to work but seems like a very experimental trick.
von
I think there is no thread you find on the first 5 google sites i have not read. And "No" HiSuite still does not work when the phone is locked.
And yes there is an Emergency Backup in the Erecovery Mode that is possibly broken or cannot be entered. Thanks for your help.
von
Antwort hinzufügen
KaitoKid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 33
Letzte 30 Tage: 147
Insgesamt: 2,164
