Zum Hauptinhalt wechseln
Die Xbox Series S ist die aktuelle Konsole von Microsoft, die ohne Laufwerk auskommt. Sie wurde mit ihrem großen Bruder, der Xbox Series X, am 10. November 2020 veröffentlicht.
Why is the Xbox Series S power light flicker and then turning off?
I'm trying to repair an Xbox Series S. When I try to turn on the console, the power light turns on for a second, and then shuts off. Other than that, the console does show any visible response to pressing the power button. The fan doesn't even attempt to start spinning up. I've tried booting the console in safe mode, but it gives the same result. At first, I thought that it might be a power supply issue, but replacing the power supply didn't do anything to fix it.
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It could be a safeguard built in by Xbox that occurs if something is broken or damaged internally. Have you tried looking around the motherboard for loose connectors? If you haven't then please try it. If this doesn't work, try a different outlet or try a new power cable.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
I've tried reseating all of the connectors, and it didn't make a difference. I've also tried it with different cables and outlets.
von
Do you have a spare working power supply? If you do then try to use that. If it still doesn't work then its a motherboard issue.
von
I have this same issue. There was water damage on the motherboard...I cleaned the corrosion with 99% rubbing alcohol and replaced the power supply (I couldn't figure out how to open the power supply to clean). It worked! I even saw the accounts from the og user i bought it from and was able to factory reset it. I was installing games overnight to play the next day...In the morning found the console off and figured it went to sleep after the install, but the issue came back! It turns on for a sec, then makes a sound and immediately shuts off. I haven't wanted to open it up since then...
von
You can try removing the SSD and powering it. If the console starts, that means the problem is from the SSD. I have the same issue trying to find a solution. Not even a technician could fix it. Said bad SSD and returned it. I suppose there is problem that is causing shortage somewhere in the motherboard. Sadly, I cannot find the source since the motherboard looks perfect.
Bewertung 0
1 Kommentar:
Did you ever find the answer?
von
Antwort hinzufügen
Jane Cameron wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 49
Letzte 30 Tage: 173
Insgesamt: 6,020
