Zum Hauptinhalt wechseln
Das Lenovo IdeaPad 3- 14ImL05 wurde im Mai 2020 veröffentlicht. Die Modellnummer lautet 14IML05.
The fan is making a weird sound!
Hi, The fan in the laptop is making a weird sound! I can’t really describe it. I really need help because I have very important things on it!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi
Unfortunately the best thing you can do here is replace the fan as fans aren’t really meant to come apart to be fixed
The fans motor,blades or baring might have failed hence the strange noise
here’s a link to the part you will need
https://www.ebay.co.uk/itm/255724423581
(Also thanks to @jayeff for helping me find the part)
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Hi @hellomacos,
The fan part # is 5F10S13907.
This may give a bigger range of suppliers.
Also is it that the fan is "noisy" or just operating at high speed and the OP hasn't heard it before when it does this? If high speed it may be an entirely different scenario to follow up on.
If noisy an old trick is to remove the label from the hub of the fan and put a single drop of light machine oil on the bearing. Sometimes there's a cap over it as well that is easily removed, other times just the label, depends on the fan. Just a thought.
Cheers
von
@jayeff
Thanks for all the amazing info @jayeff
and il try and find a fan for the person who asked the question
Cheers:-)
von
Antwort hinzufügen
Tyasas Melekälle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 45
Insgesamt: 1,383
