Zum Hauptinhalt wechseln
Released 1993, identified by word TI-82 labeled on upper right corner of the screen.
Glitched vertical lines on TI-82 Stats.
A few days ago, I dropped my TI-82 Stats calculator. At the same time, the batteries ran out, so I'm not quite sure which of them caused the problem. Anyways, when I had inserted new batteries, the screen had thick glitched vertical lines that obscure every other character. The "glitched" lines mostly look like a "ladder"-pattern, but there is a thicker line in the middle, what looks like noise to the far left, and there are some missing pixels here and there. It has looked like that since I pressed the graph button (or whatever it's called, I don't have the calculator here right now). Before that, it was an even thicker pattern. Does anyone know what the problem could be and how to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi
This is usually one of two things
1)a dodgy screen connection,the screen connector on this calculator is soldered to the main board
this can be sometimes be fixed by resoldering the connections with a soldering iron
Here’s a guide on doing it
https://m.youtube.com/watch?v=mY-tI4WQDf...
2) it could be that the screen is internally damaged ,if this is the case the screen will need replacing
The guide linked above has the disassembly guide in it
If you need a part you will probably need to get a donor calculator as these parts don’t seem to be readily available
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 3
My 9th grade Math teacher just gave me a TI-82 Calculator, when we opened the battery cover, the batteries were beyond corroded, we took them out, and took some donor batteries, put them in, and pressed the on button. And I get lines throughout the screen, so I took it apart, and couldn't find anything wrong with it. I don't know what is wrong.
Bewertung 0
Antwort hinzufügen
Aron Andrén wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 31
Insgesamt: 774
